Posts by hotsoop
    You can just create your own Filelinked store for your own personal use, this is easy to setup and manage, you only need 3 things for this, a Filelinked account, a drop box account and your apk files. Im waiting for a response from one of the modoraters to see if I am able to create threads which are not native / specific to a certain device, I have a few threads I have wrote ready to go, this is also another I could write, step by step, how to create an manage your own personal Filelinked store, until I find out if this is possible for me to do or not search for Filelinked, install it, create an account,also get your self a dropbox account to store an share links for your apks, you use the share link address into Filelinked to create your store an listed apks available for you to download, as I said I will go into ,uch greater detail if this is something I am aloud to do on the forum(obviously no sorces will be mentioned for getting your apks or no apk names will be mentioned, that is down to the user thier self)
    SAM
    thanks, it's something i will look into if normal sideloading isn't possible.
    Why not just put the .apk on a USB stick and introduce it to your Formuler that way.
    Alternatively, navigate from the Formuler to a network resource where the .apk resides and install it from there.
    thanks but it's a bit more faffing around than just using an app from my computer.
    i just want to know if it's possible to do.
    is it possible to sideload apps to the Z7+?
    i mean from another device.
    i have a mac and use adblink to connect to other android devices and add APK's.
    when i try to connect to the Z7+ i get a "cant connect to this device" message
    thanks Lucky133, found it.
    i don't know why i have never seen it before!
    i usually just click the VOD button on the remote and only movies show up.
    wouldn't mind but i never watch any VOD, it's just so my wife can watch series and i've had so much earache from her for months.
    you just stopped the pain lol.
    cheers
