Thanks problem fixed it was provider
Posts by phantomvs
since last update , my epg says loading on top right hand of screen but doesn't populate.
I tryed erasing epg, even changed setting to utc or normal ...nothing.
i know it comes from provider but elsewhere its working fine.
i have a mac sub.
Thanks again ffonseca !
I did the 9865 there is only 2 apps there.
Will stick with the 0852.
In the market, go to the first icon at last line and insert the code 0852.
Ok got it it's user market and then enter code
I kept pushing yellow button on remote I thought that's the way I did it last time.
This should be a sticky.
Thanks again !!
Nothing here doesn't respond to yellow button .
How did you do it ?
Since latest update doesn't seem to work.
I can't seem to login, anybody else try it ?
It use to work with yellow button and 0852
Thanks guys !
I will look into the M3U option and see if first provider can unlock my mac.
You could also just change your IPTV subscription to the M3U type and use that within MYTVONLINE
now that was another idea i was looking at. Cause i love the mytvonline, reason for getting z7+
you can only do that once on the formuler box right the rest are just portals ?
what would i require to do that ?
how do you get the user market to open up and install code ?
does this still work ?
I did it once with yellow button can't seem to recall.
hi guys !
I own a formuler z7+ and love it.
I just found a reseller for the same iptv service i have now for cheaper.
I wanted to change , but can't as it seems my mac address is locked to first seller even if sub is expired.
I was wondering can we use apk or stb emu on these formuler boxes like perfect player etc.. ?
Also it would be cool if formuler can change mac address like the buzztv xpl3000 boxes.
Thanks !
