My Z7+ is a few yrs old now & it has become a bit slow, epg & menus don't load a fast as they once did, overall operation has slowed down, any way to correct this?
Posts by benny44
Is it possible to backup the portals/URLs to usb & reload them to the box later?
Switch "External Player" to off. Go to Android settings -> Apps -> Mytvonline -> delete cache and data. Start Mol1 again, start some movie with standard player. If standard player works, go again to Mol1 menu , activate external player, start again movie and choose VLC player.
I will try that today thanks, will deleting cache & data get rid of my urls?
I am unable to select VLC as the external player, vlc app is installed & external player option is "on" in the settings menu but it still uses another player, I used to be able to select from several players but not anymore, Z7+
Offset change affects allways all streams.
thats what I was thinking,...thanks
One of my streams has it's epg +2hrs ahead of my local time, is there a way to adjust this without affecting other streams?
You're Welcome
m3u/XC method is useful for me as I can use the same connection on a small firestick when on holiday with another well know app, where as using a mac address method isn't as portable, I also have mac connection but for home use on the z7+,...thanks again.
How to use MAC/ID portal, Xtrema Codes Api (XC) and M3U Url on Formuler Boxes.
Take a minute and look at this article I think you will find it useful.
Well smack me in the mouth with a wet fish!.....I never knew that could be done in MTOL, just tried it & it works 100%, pulls in everything including live tv,epg & catchup,...even VOD, just needed to enter the relevant info from my m3u line & bingo,....many thanks
For what use with you have with a 3rd party app?
I use all my mac portals on the z7+ & I use the playlist option too,...my Z7+ & mac address connections are for home use as is the m3u playlist connection but I can also use the m3u connection whilst away from home on my small amazon firestick,...you understand?
Im a bit confused about this topic,..I use the following method to load my service in the playlist section on MTOL Z7+, the bottom line pulls in the epg.
http://EXAMPLE_url/get.php?username=EXAMPLE&password=EXAMPLE&type=m3u_plus&output=ts
http://EXAMPLE-url/xmltv.php?username=EXAMPLE&password=EXAMPLE&type=m3u_plus&output=ts
People should just convert their m3u into an xc login and be done with it.
Yes but that would mean using another 3rd party app installed on the full android side of the Formuler box,..MTOL is far superior.
Any rough timeline for that? Are we talking 1 mth, 6mths, 1yr
any update on this catchup topic?.....just wondering.
Can someone provide step by step instructions in non-expert language how to do this?
If you have a current subscription to a service using the Z8 mac address you just need to replace the (virtual mac address) generated during the STBemu setup with the mac from your Z8,......thats a simple as it gets,...forget about id's, sn's & everything else mentioned above.
Anyone know of how to load bbc I player on a formuler z8 box through google play.. I can find the app but there’s no option to install? Just says not compatible with my device? Yet it’s an Android app?
the problem is that your playstore login stores your location & thats why iPlayer wont download for you, the location you included when you signed up to google playstore was outside the UK, BBC are very strict on not allowing non UK residents access to iPlayer content, I used a vpn & set my location as the UK then I side loaded iPlayer from a usb stick (search for BBC iPlayer apk file) once you install iPlayer you then setup an account, all this must be done with your vpn active & set at a UK location......any time you want to watch iPlayer content always run the vpn first & set to UK,...disconnect vpn when not using iPlayer.
I had the same issue, the formuler remote does not scroll the screen in iPlayer ITV hub or Netflix, I bought a cheap air mouse & its great.
I hope so too, I had to buy an air mouse remote to use with the Z7+ because the supplied remote does not allow you to scroll the netflix
screen....very frustrating.
