How are we supposed to trouble shoot issues if we aren't allowed to post specifics about the issue. What a joke.
Posts by Tsp84
Gigabit usb 3.0 adapter(get the Anker gigabit adapter that has 3 USB 3.0 ports built in) , or a wifi dongle based on chipsets in formuler helpdesk. For the money we're spending these features should of been built in.
Beta SW fixes *****epg populating. ***** xml still don't work. Can anyone else confirm this? Possible bug in XML parse? As the epg works in other clients.
Just to let you know that Amazon Prime works fine on the Beta Build of Kodi 18. Got Netflix Semi working - Now
Will do full guide.
Did you do a guide for Netflix and prime?
I updated to beta and it works fine now via *****with gzip
I cannot get some epg files to populate mol using m3u playlist; specifically *****p2.xml.gz and iptv-epg.com xml files. Xtream editor XML files populate mol fine. I have software and factory reset, there are no typos in url, and in other clients (Kodi, Perfect Player, GSE IPTV) the epg works perfectly from *****and *****. Apparently, as far as I understand, the beta formuler fw or sw populates *****epg, I a on the public stable fw and sw. Can anyone else confirm these findings? Thanks in advance for any ideas or suggestions.
I have software reset, factory reset and re updated and still cannot get *****epg to load via m3u playlist slot in mol, same thing for an uncompressed xml file from *****. However, an uncompressed XML file from xtream editor works fine in mol. Pp, Kodi, smartiptv etc can all read and populate the epg for ***** via their p2.xml.gz file, mol cannot. Can anyone else with the current public stable software and firmware confirm this?
By beta, do you mean beta formuler software or firmware? so if you can load *****m3u and epg, should I try software and factory reset on formuler? I can't get *****or iptv-epg' epg data to populate mol but xtream codes xml files work, the url works in all other players I've downloaded on formuler box. I only have this issue on mol. And yes I've re entered the urls numerous times with a keyboard and copy pasta through air remote z, so no mis types. Are there any settings on mol that would affect this? Buffer seconds, hls loading etc.
100% doesn't work for me and I'm not using the beta. I tried making my own epg with iptv-epg and it isn't populating the epg on mol but it works perfectly in Kodi on the z7+. Xtream editor XML file populates the epg for mol and Kodi alike.
Mol doesn't populate the epg for *****m3u, whereas Kodi on the formuler does.
For some reason mol won't load *****epg when using m3u playlist. Using Kodi from home screen and simple IPTV client, the epg populates for Kodi. So I know the gz file is there and other clients can read it but mol can't. Is this a known issue or is it something new?
How do I tell if the epg has loaded? I am using an m3u playlist and no epg data
