Posts by dp4
    Loved my z12 that much bought another for a different room but when trying to setup I’m getting this error . I’m in the uk not on any vpn or anything
    Reset to bootloader and done a factory wipe and get same thing .
    Can anyone help with this as I’d rather set it up than have to send it back
    This product is not for sale outside EU/UK.
    Contact your seller.
    Just one idea. Could you please change the 2.4Ghz Channels ( router) from automatic to fixed one or if set already fix to automatic? I saw few times that router get problems with 2.4Ghz and hard used channels, then he steel Z7+ almost complete bandwidth, result is collapse or buffering.
    In this case is 5Ghz the solution, of course if this is the problem.. If you can, test with gigablue wifi usb dongle -> S and Z series compatibility test and devices. , should help to get stable con. in 5Ghz network.
    Cheers for the advice I’ll give it a try .
    Should never have left virgin media for the internet nothing but problems since I changed it over
    Model: Formuler Z7+
    Retail Box or Provider Box: Retail Box
    Firmware version and date: - latest official one (not beta)
    MYTVOnline version and date: latest official one (not beta)
    Did you factory reset your device? and when?: yes I've tried it a couple of times
    What issue(s) are you having? (please provide full details of issue in an easy to understand manner)
    The box keeps disconnecting from my internet connection approx every 5-10 mins, then I have to either disconnect the wireless and connect again or I have to reboot the box , I have to connect by wifi and the box is right near the router.
    I cannot connect by ethernet cable as I have sky q router for the internet and there is something up with the router as it won't keep an ethernet connection at all for more than 5-10 mins on anything , this I believe is an issue with the router firmware as I have been through 3 routers and many cables all with the same result. -
    however all my other devices are ok with wifi. I have on average 73mb down and 19up speed.
    I was on virgin media internet when I first got the box and that worked great.
    What have you tried if anything to rectify the issue? (i.e. rebooted device, factory reset, powered off device, replaced cable etc.)
    Replaced cables , changed router 3 times. , factory reset a couple of times , I have even sent the box back to world of satellite and they tested it for a few days with no problems. I have changed the wifi network onto different channels and tested both 2.4 and 5g
    I know this is more likely to be an issue with my router but would there be any reason why the formuler z7+ keeps disconnecting from the wifi
