Thanks. I will make sure not to install that update then.
I am waiting for the supposed March update that is supposed to fix issues with M3U/Playlist Portals not saving favorites.
Posts by spence
Can you tell me what version it is that u have installed that has this fault?
In future i think yes, maybe with MOL2 when it comes out.
Any rough timeline for that? Are we talking 1 mth, 6mths, 1yr
Dont really want to go with MAC as then I am limited to just using that box. M3U allows me to move around and watch on things like VLC or Smarters APK etc.
I think Mevi just clarified what you already said.
I would also like to know if the m3u will work with catchup in future. -
In Settings>Portal there is 5 places for MAC and 1 for Playlist within MTO.
Is there any possibility to increase the allowed number of m3u/playlist connections?
M3U allows for more connections from providers Eg: 3 connections via m3u.
I have noticed that I can add some of my m3u details into the "non-m3u" portals and it will take the details and connect. So now i have the same provider with same credentials in MAC Portal and Playlist Portal (I have only paid for m3u from provider).
But the EPG is not fully functional and the favorites never save in the non-m3u portal.
I have also noticed that the portal that is "non-m3u" seems more stable and has less buffering.I would appreciate some feedback/input on this.
Edit: I just saw that there is a request in the wishlist thread for multiple m3u, but would still appreciate input on the other points.
Thanks.
I would also like this very much. Thanks.
Also interested to hear if this got looked at or implemented.
I would like to buy a Z7+ but waiting for this confirmation.Thanks.
