Posts by migasmike
    To scroll down:
    1. Press mouse cursor on the remote to enter mouse cursor mode.
    2. Press CH UP/Down buttons on the remote to scroll the screen up and down.
    Let me know if it works
    It´s working with your tips, but will bet beter if we don´t have to use the cursor on the remote control, like i have in my MEO Box http://www.meo.pt .
    Today my formuler Z7 + have made updates of firmware: v1.2.71 and IPTV Version v1.9.71.
    Netflix stops working. I had to uninstall my netflix and install the last version of the website of netflix and intsall it on the z7+ but always give me the following error: "Sorry, we could not reach the netflix services. Please try again later..... Website (0013".
    Have to uninstall and install the version from the store formuler.
    When i lunch the application says New version find it (update or cancel), if i click update appears a error something like this: This application is not compatible with your device. " i click cancel and works.
    The forward and rewind it´s not good, because we can see the action... in my MEO http://www.meo.pt i can see the action during forwarding or rewind.
    Im curious about your feedback
    Hello!
    Already try.
    I delete Netflix and download from the official website, but i have the some problem.
    when i choose a serie and the session that i wanna see and if they are many episodes i try scroll down to chose the episode that i wanna see (the menu goes out of the screen), but i can´t do it.
    " This message disappear:
    I install the Netflix from the store of the Formuler Z7+.
    If i click cancel i can open the Netflix. There is a problem that i can know work around. I choose a serie and the session that i wanna see and if they are many episodes i try scroll down to chose the episode that i wanna see (the menu goes out of the screen), but i can´t do it.
    I have been testing this product for about a week now and all I can say that it works perfect !
    No buffer on 4K VOD movies, no buffer on IPTV channels.
    I recommend it to everyone who has problems with buffering:
    https://www.aliexpress.com/item/IOCREST-u….41084c4dbIdAay
    Mevi
    I tested my formuler Z7+ with a external USB 3.0 Ethernet adapter and the buffering problems are the same! a lot of buffering.
    Tested with https://www.tp-link.com/us/products/de…3_TL-UE300.html
    Mevi
    It´s supposed we have problems with Ethernet connector of the Formuler Z7+ (10/100Mbps), to buy a USB external RJ45 gigabit adapter?
    No make any sense in my opinion.
    Happy new Year
    Cheers
    Evening
    I am now nearly certain that the buffering has nothing to do with the box or how it is set up and all to do with mytv app.
    I have three providers linked to the mytv app today it has buffered like crazy to the point where all of them were unwatchable.
    I decided to install the providers own apps and I haven’t had a single buffer with them.
    Any idea what the optimum settings are for the mytvonline app?
    Do you have a box from other brand, to test your three providers?
    Cheers
    My advise, open a ticket on https://support.formuler.tv/new
    Formuler have to assume her responsibility.
    Cheers
    Of course it's related with Formuler!
    I've changed to static IP, it does work better. Sometimes when I open some channel it's freezing from the beginning and when I change to other and go back to the same channel, it works fine. It's clearly bug with the device!
    As I wrote before, there's no issue when I use a different device with the same IPTV provider on same channels!
    I've tested on my TV with Smart IPTV, my laptop with VLC, my phone with couple of Android applications and all of them are working fine. SAM
    SAM
    I agree 100%
    i have made the same tests has you do and the conclusion are the same!
    Formuler related problem.
    Cheers
    SAM
    I had open a ticket in Fomuler support, considering the problem of many users have about: "Buffering issues" (The same issue of this topic).
    It´s seems the Formuler don´t wanna take responsibility of the Buffering issues on their Z7+ box.
    Formuler Support response:
    " Buffering issues are a provider/internet issue almost 100% of the time.
    What provider URL are you using, and what is the providers website/contact info I will try to replicate your issue.
    Sincerely,
    Formuler Support "
    Guys, i can say that i have another box, a cheap box from a Chinese brand and works very good, without buffering issues problems.
    Sincerely,
    Mike
    Mike, I changed to (Manual) Static but it doesn't make a difference for me. I have buffering on HD channels and on HD Catchup it is unusable. My connected speed is generally in the range 12-15Mbps.
    The same HD channels are working flawlessly on WiFi on TV Mucho for both live and Catchup. Definitely seems to be the Z7+ that has some flaw.
    Also the EPG is very slow to load as mentioned elsewhere.
    SAM
    One more reason to Formuler fix the problem.
    My connection on HD channels is between of 6Mmps and 8Mbps.
    In 4K between of 12Mmps and 20Mbps.
    Of course the speed depends on the provider.
    I never test my box in Wi-FI Mode.
    Cheers
    In the MyTvonline is possible to have more then one provider?
    I will try to explain:
    In services, we can edit the service and put something like this: ht*p:/*the.serverurl..com/c/ (is this the portal?, that works by MAC address?)
    In services we can find another menu, here we can put the m3u link .
    Can i configure both providers and choose what i wanna see?
    If possible, how can i switch between then?
    Thanks,
    I am running my Z7+ on an Samsung LCD.
    I would like to customize the color, brightness, and ... on my Formuler Z7+ special when i´m using the application MYTVOnline.
    Comparing to other image from different devices that i have connect via HDMI to my TV, the the color is very saturated and i don´t like it.
    It´s possible to change the color setting of the Formuler using some feature belongs to the box? Or just can do it on the general configurations of Android?
