Posts by Chocolat65
    One thing I have noticed, is that the Z7+ become hot (very hot) when the buffering starts. Could it be this be the explanation ? Critical temperature is reached...
    To Rickiev : I understand your point of view, but what I can not explain, it works fine for 45 minutes, then bufferings starts (also frequency of buffering increases). I have this issue only with some 4k VOD streaming (not all...), no issue with FHD or normal streaming.
    Kind regards
    Chocolate
    Hi eveerybody,
    I have an issue while watching VOD 4K : everything runs smoothly during the first 30-45 minutes, then the buffering starts (frequency +/- 3 minutes)...
    When I reboot the router or quit MytVonline and go back to the movie, it runs smoothly a few minutes and then buffering starts again.
    Using a VPN or not , does not change anything.
    My Z7+ is wired (Wifi is even worther), Static IP outside DHCP range. DNS switched to 8.8.8.8. Connection speed : 92 Mbps down .
    Could a direct PPPOE connection help ?
    Thank you for your help
