Posts by Foxy147
    this is clearly a known issue and has been for a while so i wonder why it has not been addressed already, Have the same issue, only on MOL3 have tried 2 other IPTV apps and they're ok, apps like youtube etc also work perfectly..... also have an issue where sound is so high on some channels and low on other and when checking the audio track can see that it is different, again those channels are absolutely fine on other apps, it's pretty fair to make the assumption that this is a MOL3 issue so why after so many reports has this not been resolved already?
    Better features for when adding via m3u playlist as i don't see the point in having that option without the features and i have adjusted my playlist to my liking so have to add it via m3u and likely wouldn't of bought the box if i knew
    1, Group channel numbering- looking online it suggests this feature was available on MOL2 but not on MOL3- again requesting this on an m3u playlist not just xcapi
    2. Adding the catch up feature for M3U playlist- I don't know why this feature has been left out, the app itself is very good but little things like that really let it down as it means having to use a separate app for this as quite honestly it's better
    3. Fix bugs or whatever the problem is causing the app to crash a lot either when changing a channel or just suddenly for no reason... looking on forums this is a very common occurrence that many people are experiencing
    i am relatively new to formuler but the crashing is happening pretty regularly which is a shame as the set up of the box is very good. Hopefully this can be resolved soon.... also whilst i'm here does any one know how to change group channel numbering? everything online advises it's possible on MOL2 but can't see anything for MOL3 which is annoying as i have created my own playlist and wanted to use the channel numbers from that not just have every category starting at 1... really hope someone can shed some light
