Posts by Orcman
    you cant as far as i know if you login with user/pw as epg when you log into your iptv provider is server based
    but with m3u you can leave epg empty meaning no epg , but as i said i had cashes too untill i registred my mac adress on my provider and used the magportal adress
    it might not work for you but it did for me
    right finaly figured how to get vod filter and search to work :smiling_face:
    first you have to register your mac id with your iptv subscriber , once you have done that you will get a mag portal adress if you use that adress vod filter and search will work.
    kinda strange that you must register mac id with your iptv subscriber to make it work imo
    nope
    i have even asked my isp provider and he has an z7+ and he has no problem with same software/firmware as i have and tried bypass my router also with no success
    so sorry i got no clue what is going on :frowning_face:
    vod filters or search dont work on my z7+
    search find nothing for me and on filter i can only select the sort order which dont sort anything and i know this isnt a provider isssue because vod works on any other app like iptv extreme so would be nice if someone has a solution for this
