So is it possible on NEO or Alpha install apps to USB stick?
Posts by thomux
the same here
Nano Z - multibitrate OK
Z7+/Zx - mutibitrate not working
Z8 multibitrate - OK
tried all this stuff still remote only works TV on/off and Source change.
in year 2020 android 7... usb 2.0.. only 2.4ghz for 79eur sounds very very overpriced. If it changing in product range nano z the price should be like nano-z.
is it possible to add apps to be installed automatically with deployment tool?
is molcfg for Z8 out?
On XC found that there is cloudtimeshift and it is working,
What do You mean by ministra is not supported. Formuler working like charm with 5.3.0 ministra (last version which is supported).
On ministra 5.3.0 catchups working on formuler but how to get Cloud Timeshift (Server timeshift) working on it
How exactly is possible to use ministra or xtream timeshift on Z8. Catchups on both working fine but how to use timeshift. Support of formuler doesnt answer to emails. Maybe here can anybody explain how to do this.
So how to Rewind on stalker api to the begining of show if it goes already for some time without USB?
Still dont understant. On stalker boxes i can just press rewind and get live stream from the begining. Without any usb. Is it possible with formuler z8 or no? As I understand provider has ministra portal and making archives on his server.
if portal provider makes server archives on-the-go will i have possibility to rewind not finished event or no? I have now 2 different producers boxes which do this, but one I want to change to z8. will i have this feature cause it is very important for me.
usual way like other boxes with portals support? Just when watching can press rewind and start watching not finished event from the begining?
Does the timeshift working on Z8? On May was written that it's coming soon
as I understand Formuler support didnt read this forum.
Will the timeshift from stalker work on formuler
there is no any new protections on ministra. Why oder producers of boxes works without any updates. My opinion the problem is that formuler indicates as mag200 why not to make as mag250 or mag254
Will be any solutions how to solve the problem? Checked that on 5.4.1 it is not working too. Only 5.3.0 ant older
so still no news about 5.5.0 support? Tried on different products the problem stil not solved on MyTVOnline only
Will new MYTVOnline Version support 5.5.0 stalker?
So any Ideas? On other boxes it goes only formuler gets error tried on different formuler boxes nano Z/Z+/Zx:
"Your device is not supported"
On different producers of box'es like ***** it goes like charm.
When it's planning to be fixed?
