Posts by thedoct
Good morning all
On the Z8 Pro remote control, I can't find the cursor movement function with the arrow like on the z8 (see the attached photo of the Z8 remote control), does anyone know if the Z8Pro has the function? I did not find thank you
Hello
yes i checked
it is only 1 subscription that has this problem of evening and morning
I tested 2 more and it works all day
Hello everyone
so I work with the vendor on this problem
active mac address
Thursday morning connection portal active ok
Thursday night impossible to launch the portal
Friday morning connection portal active ok
Friday impossible to launch the portal
this morning active portal connection ok
it is not a problem of internet flow I test each time there is always more than 100mpbs
my provider ma search my IP Public with the app IP-tracker
I found this IP and it has apparently connected and it worked this morning
tonight I go back, I try to connect the portal, nothing, I'm doing an IP search and I see that it has changed ??? I think that is why my portal does not connect tonight.
I have to install 2 times in DHCP auto, must I install in static ip?
mac address works since it works with another subscription
url i did live with the provider it works under z7 + and it does not work under z8
hello
I just changed z7 + for z8 and I have a problem installing a portal
The installation starts at 10% stop and I have a "code error 7"
I reset twice, I installed 3 different portals. 2 portal launch and the 3rd makes me this problem. internet is ok
I try to solve the problem with the supplier he tells me that everything is ok. we tried to put this portal on z7 + and ok it works
Has anyone ever had this problem
thanck
hi
Ok I use à translator
Thanck
now it's been 2 weeks since I try to record programs via EPG "scheduled recording"
formulate Z7 + and mytvonlineI manage to record 20 / 30min and it cuts itself
- I tried with
- 3 different suppliers (my abo and 2 test versions)
- many different channels and different days and hours
- I did a factory reset twice and empty the mytvonline cache, it works for 2 days, then everything starts again.
- resolution set to 1080pp, memory formatted between 466mo and 0.9me on 1.9 GB
I look on the forum formulated in English and apparently I am not alone in this case. but I have not found a solution
I even tried to record live over a period of 5 hours, but it was cut off after 1 hour.
can someone register via the EPG registration program?
thank you for your return
Code
Bonjour J'ai exactement le même problème, l'enregistrement programmé via l'EPG ne fonctionne pas, il s'arrête après 20 à 30 min. J'ai déjà initialisé deux fois le formulaire par réinitialisation initiale. ça marche 2 jours puis ça recommence. J'essaie par différents canaux, le problème est le même. Je vais essayer par un autre fournisseur mais je suis désespéré. Quelqu'un at-il résolu ce problème? même la dernière mise à jour n'a rien changé Je vous remercie excusez-moi, j'utilise un traducteur
