Posts by bfragilis
    I have seen some Z7+ with really bad internet speed connection. Even using good quality cables, usually these boxes get better speeds on WiFi :frowning_face: wich is hard to understand (not all boxes, just the ones that get low values on connection speed!)
    I use a wired connection with my Z7+. I get about 20 MB/s without a VPN and 15 MB/s with. This compares to 200 MB/s on my laptop (via wifi).
    So overall, I'm not impressed with the connection speed on the Z7+. And the issue may be more with the intrinsic hardware than with its wifi abilities.
    I've developed an odd problem. When watching either live or catch-up TV, the pause button works to pause, but the play button doesn't work to resume. (Nor does re-pressing the pause button.) The only way to get things working is to change to another channel and then change back.
    This just started in the past couple of days. Before that, it worked as expected.
    Any thoughts? Thanks.
    Edit: OK, I just found a workaround...The stop button causes play to resume (paradoxically). This isn't the expected behavior, right?
    Newbie here...
    I just got a Z7+. I'm currently subscribed to GearsTV, and it works fine using the apk.
    I'd like to use it with MyTVOnline, but the reseller tells me they do not have a portal url, and that it can only be used with Kodi. (The apk obviously also works, since that's what I'm using.) So, how do I know which providers do have a portal url, and can be used with MyTVOnline?
    Thanks.
