Its for android 5 and higher. You can always try an older version yes.😃
found a solution. If I disabled "enforce 3D framepacking output" in android settings for video output it started as normal ![]()
I wanted to clear everyting on my z7 so i did a factoryreset. No i cant even open mytvonline. It says something about "iptv info error (network)(-1)" in update. I have tried wifi and cable. I can access Google play however and download other apps. the marketapp doesn't connect to internet
What happened?
Tivimate worked also on Z7, check the specs for your version and which Android OS is necessary. Z7 have OS 7.0.
Okeey..so you saying i perpaphs need to find a older tivimate version?
Tivimate has never worked for me on my z7. Tried thrue Google play and from a usb with apk. Shouldnt it be supported?
Display MoreDo software reset.
Restart
That worked by me.
If not,
Then do after software reset a factoryreset.
Let me know my friends
omfg. I just discovered the classic mode is there. I just typed wrong key 😅 I thought it changed when hit the up button to get the channels. Now I hit the "ok" button and there it is. As I wanted to. I'm not used to this layout /hotkeys.. going from dreambox openpli
Just bought an formuler z7 and was trying to learn the interface. Saw on internet that an option called classic for the bouquets exist. So I have choose it in settings but nothing happens? Why?
Can't stand the other laoyut. Find it hard to navigate. Classic mode is exactly what I want. A restart won't do any different
