Posts by blackking
    Come on you can't blame mol cause they have not changed anything with their software and how its works. It's providers that have changed their portals since the so called "Armageddon" breakdown. Of course mol needs to adapted so the panels work.
    Exactly. It's MOL that needs to update their software because all the others work.
    September 18/19 exactly the same date XC went down. Google it and you will understand why you are having issues. Nothing to do with MyTVOnline.
    Sorry but the problem is definitely the MOL app. I switch to the STBEMU app meanwhile and it works no problems, same box (Z7+)...
    I'll just use the STBEMU app until the next update...
    It's providers side, nothing to do with Formuler, will probably be fixed soon. For now use the m3u line.
    Here is what they answer me when I told them to reset my MAC address and that the problem was on their side:
    "Hello,
    They are lying. Your plan was already reset. There is a compatibility issue with the onboard software on those devices (Formuler Z7+ etc...) and the new system. You will not be able to make it work. We can switch your plan over to Streamline Hosting if you like for use with our android apk's and other third party apps which use m3u playlists.
    If there is anything else you need help with Please don't hesitate to contact us. If not you can hit the "Close Ticket" Button below.
    Thank you.".
    So I guess we have to wait for an MOL update...
    Here is what I got from my provider: "...Your plan was already reset. There is a compatibility issue with the onboard software on those devices and the new system. You will not be able to make it work. We can switch your plan over to Streamline Hosting if you like for use with our android apk's and other third party apps which use m3u playlists.
    Thank you."
    I have 4 android boxes, 2 Formuler z7+, 2 android tablets and 3 smartphones most of the time connected to my network. The TABLO OTA DVR APP downloaded from the GOOGLE APP STORE works on all of them but the 2 Formuler Z7+. The app installs and opens but it crashes all the time as soon as I click on "Live TV". So I know the problem is with the boxes, not the app.
    Can you guys check this out, because I really need my OTA TV.
    I don't wanna have to go back to paying cable... :face_with_tongue::face_with_tongue::winking_face:
