Posts by villiers210
    This is kinda difficult to explain - please bear with me 😁
    I have two z7+ boxes (with subs from 2 separate suppliers) and got this problem on both. On some foreign channels, sometimes there is audio, sometimes there isnt. Initially I thought it could be a sub supplier problem.
    However, when there is no sound, if I wait til the advert break comes on, and go up a channel then back down again - hey presto, I got sound. For some weird reason, this will ONLY work during an advert break.
    Any ideas please? Its driving me crazy.
    Dont know if this may help somebody. My internet speed is around 72mbps, but when I tried with VPN (I tried several) I was only getting 18 or 19.
    I tried loads of different settings on the VPN, all of which didnt help. As a last resort (after hours of messing) I rebooted the router and boom - speeds through VPN now in excess of 45mbps.
    Must confess I was always sceptical of this "unplug wait 30 seconds and reconnect" advice, but it's worked for me.
    Thanks for the reply. After investing in 2 boxes (z7+ and z7+ 5g) upgrading to a z8 isnt an optional on my budget I'm afraid. I do hope that serious consideration is given to this request - I know I'm not the only one that needs this feature.
    Would also be an almighty shame that apart from this, these boxes are awesome.
    Thanks again!
    Sam, what I mean is recording a future programme but NOT through the epg. In other words by setting the date, channel and time to start and stop recording.
    The reason I need this is that I watch several Polish channels, and none of the providers issue an epg for those channels.
    Hi ' I have asked this question previously, and I know others have too but cant find an answer anywhere.
    I have 2 boxes , a z7+ and also a z7+5g. Basically, I know manual recording is not available yet, but is it going to be introduced via an update? If so, any idea on timescale?
    This is a "must" for me and would just like to know if it is on its way.
    Thank you
    Don't know if this is of use to anyone, but after trying all the suggestions listed here, this finally worked for me. I have a z7+ which started buffering really badly, mainly on HD channels but also on a few SD channels all of a sudden a few days ago. Im getting 34mbps as reported by "speedtest" app that I installed on the box. Now a mate of mine has exactly the same box, and uses the same provider as me without any problem whatsoever.
    So after trying all the suggestions without success, I stopped to think what the difference was between my box and his, and the only difference is that I run a VPN. So I tried selecting different servers for the VPN but still no luck. Then I turned off the VPN and hey presto - Buffering has gone and I got a 100% rock steady picture on all channels.
    After playing around for hours, I also found that if I use any VPN server on protocol TCP its absolutely fine, the problem only arises when it is switched to protocol UDP.
    Hope this might help someone.
    Please help!!! I have 2 issues
    1/ Even though my provider provides catchup, when I try to access it I just get message "Can't play this video, please try again later".
    2/ When I download a film, it downloads it to the z7+. I would rather it downloaded to my connected 1tb HDD, but can't find anywhere to change settings. I would be very grateful if someone can help. Thanks
