Hello ,
SAM Stalker protocol any update ?
Hello ,
Ok, was able to reproduce the issue through starting the catch up video from main EPG. Cloud Timeshift is not affected and works with 24 h timeline, please use this for now if possible.
Created Video, description and forwarded to Formuler devs. We need now to wait until devs. fix the issue.
How can I do that? Can you explain me ? Thx a lot
Ok thank you, will try to reproduce today and come back to you.
Ok SAM, thank you.
I don't know exactly what you mean ![]()
But its so: I want to watch a program that aired yesterday on channel X , the programs are automatically recorded by the IPTV provider. I can get the program to play and pause but I can't go forward, for example in advertisements...
After factory reset, and beta Installation still not working ![]()
Hm, this issue was fixed in last Update. I recommend to install latest beta and test again. If that doesn`t help then factory reset and install of beta again.
I installed the beta version, but tomorrow i will reset and try again ![]()
Do you use latest FW and SW update?
Left and right arrow doesn`t work?
yes i did it, and still not working...
the strange thing is that if I click on a channel that is playing live that started some time ago I can go forward, but in a playback it doesn't do anything and at the end of the timeline it appears 00:00, as you can see in the image
Hello, first I apologize if this is not the right place for my problem.
When I try to watch an automatic replay of MOL3 on my z11 pro box, I can't move forward or rewind in the timeline, the timeline appears but I can't move forward.
regards
