Posts by Parryperhar
Hi
Installed the Beta updates today. System working smooth. No issues so far.
Hi
When can we start seeing the Beta updates for the June end firmware release?
Is The update which was schedule for june end has been postponed? -
Unfortunately i m not using m3u playlist. Instead i am using portal url.
I have been using IPTV service on my Z8 box. My provider has Some Radio channels but Z8 box is not able to play Radio channels. I can see the Radio Channel list but not able to hear anything. I went to my provider and talked to him. He showed me the Radio channels working on other iptv boxes so definitely the radio channels are working from the server but Z8 is not able to play them. I think Z8 is not supporting some Particular Radio Codec.
I installed IPTV Smarters app on my Z8 and that app was able to play Radio channels.
Thanks in advance for you support.
Updated to Beta version.
I am loving this box now. Works perfectly awesome. All the major issues are resolved with this update.
Formuler has Best support team.
Thanks guys.
When can we expect new update? This way its hard to use the box. Also i am a seller for these boxes. I won’t be able to sell it before this issue is fixed.
I have tried 5-6 servers on the box and none of them shows the tv series. All of them shows the first episode only.
I spoke with server guys also and all of them are saying Formuler company has to send a update to fix it. Tv series works very good on Formuler z7+ boxes and other brands but just doesn’t work on Z8.
i am using yyyy server portal as well as yyyy server.
Admin edit: Don't post portal names..
I m using Portal url.
My mac is
1) not seeing the cover pictures for any VOD file
2) Series doesn’t show up. Only shows and plays first episode.
Admin edit: Never post your ID or mac public!
Having issue with TvSeries. It doesn’t show the episode series. It only show first episode. Is there a way to see all the episodes? Will there be a new update to fix the issue? Also vod doesn’t show the cover pictures of the files. The icons shows blank.
