When you are setting up your portal, It will show what adress you should use, but i agree.
Posts by PibesiLL
Hello question for z7+
Inside my MOTV settings i can see
mac xxxxxxxx
ID xxxxxxxx
I use ID in my iptv dashboard and it works, its the same as on the box it came with and on the sticker on the box it self but what is mac adress for inside the settings ? -
have you test to connect with a VPN
test with speedtest app
What do this app do for us?
Should i change some settings in the Android settings after install and reboot ?
vpn clients that use wireguard is much faster then open vpn
test it at tunesafe
