Well I just had the same issues on both mol1 and mol2 with my provider. I told him to come and contact the dev's here on the forum and see if they could fix this issue. My first stint with this provider I had no issues at all. But with this latest one, I have just been having problem after problem. So I hope they do contact the dev's.
Posts by KoshX
With this new obeta we should be able to manually record. Could someone explain how I could manual set and record something. And I don't mean to hit the record button. I want to record something that is not in the epg and is the next day.
Same here can't see anything or do anything in schedule manager.
If I use normal my offset is 7 hours for all channels. If I use utc it works fine but I get 5 channel that the offset is more than a day off. I know wierd. But if I just had 1 more extra hour to offset I wouldn't be having this conversation. The only reason I said 12 hours it would cover 1/2 day in each direction.
Thanks Sam much appreciated.
Is there any chance of the developer's could increase the amount of offset. Under normal EPG guide I need to offset it to +7 but I'm limited to only 6. Why can't we have a 12 hour offset? Would make life easier.
I would use xc api. I have found that the epg loads a lot faster than m3u.
Google won't give it LV1 because it's not using an official android. But I have heard Netflix is creating it's own standard called Hailstorm. Hailstorm would be looking to certifiy by hardware not OS. Can't wait for that to happen soon enough.
I had a 32g USB. But now I'm using an old 320g hard drive and it works great never have to worry about space. And yes format it to NTFS.
ok thank will try.
Just want to know if anyone else is having the same problem or is it my provider. I can't seem to get the movie information in my VOD section of MOL2. Forgot to mention my connection is through m3u.
A quick question do have to do the factory reset? What of I don't want to do one. Will it be a problem, because so far I have just minor issues. Which I think are on my end. I think my router is just crapping out. Time to build a pfsense router.
Once you enter the code 0227 a red rectangle will show in the bottom right. Press the red button where there are 4 colors. It will pop up for a beta firmware update then.
Hold down the OK button and it will give you the option to delete all or 1 file. If you want to delete 1 file just make sure to uncheck all files. Just did it now myself.
It wont get Google Lv1. But Netflix has started it own certification program called the hailstorm program. With that it will soon get a certification for Netflix. But you still won't get to watch Amazon video in HD.
