Create on your USB Stick file folder "M3U" and copy the file inside. Then under connections lead mol2 to this file.
I did exactly as I said but it still did not work ... I never got the EPG to work either MOL1 or MOL2 ...
my Provider has provided the link but still does not give. is the only application that does not work
how do I access the storage to put the gz file? I tried to access the folder and it appeared to say empty storage
Hello. How to run EPG from a m3u line of the mytvonline2 application? I've never been able to run the EPG on a number of services I've had
i think your 'very near future' comment is highly inaccurate
oh no .... the years experience of android in the pits has proven that same
Which apps run on Android 8, but don't run on Android 7?
for now there is no such problem but in the very near future will be problem
These boxes run heavily customized and well developed firmware so what advantage would using android 8 have over 7 for an iptv box such as the z8? The OS is nothing but an interface to the software you want to use, like MOL2. If it runs smoothly and runs the intended software properly, who cares if it's android 2.
Due to new features that every new hardware brings. Who says features, also says features. Not forgetting that each application is evolving and no longer supports previous versions. remembering that the form is not only MOL2 .... who buy these boxs of course buying because of iptv but also everything else that comes in it. remembering that it is a multimedia box (the brand itself does this advertising).
There is no plan to update to Android 8
strange if the form itself stated this
I emailed formuler a couple of weeks ago they said they will update to 8 but they don't know when
that's great news. will there also be news regarding Netflix HD? because it is the only thing that fails to consider this perfect box ...
If you notice that link is described as Android 8. But my question is if someday will update to Android 8 ?! Well if so the only difference that exists between this box and z7 + is the Ethernet port .. another question I have is if they ever get certification from Google because of Netflix in order to operate Netflix TV and in FHD / 4K ...
Personal I need your information or knowledge ... I saw advertised on several websites for sale that this box has Android 8 ... I bought it and what is my astonishment I will look at the settings and see Android 8 ... on the website of the united kingdom speaks in android 8 but in the specs speaks android 7 ... there is a big lie here. anyone know if it will upgrade to Android 8?
