wow, thanx a lot problem solved. stupid me overlooked this in the settings.
Posts by mariod
installed today a brand new Z8 with new updates Firmware Version : 1.4.62 MYTVOnline 2 : 7.7.1
im getting very annoying 3sec.black screen and AFR : 25 Hz or AFR : 30 Hz. Does anyone know how to disable this ? i've been changing the settings for hours.....
My older Z8 with firmware 1.4.22 and Mytvonline2 7.2.2 is working perfectly.
Hope i can solve this. Thanx a lot !
provider is confirmed. no problem there. the connection just does not start...after 5min i get message to check internet or portal.
internet has been checked, tried different servers, different logins...
problem started after update. before running perfect for 8 months
same problem...after update mytvonline does not connect to portal anymore....
any solution ? factory reset ? how to refuse update ?
Thanx
edit : after factory reset no mytvonline is installed....only download v1.9.62 is available
and now ??
