Is there any chance this app will also be possible with IOS Apple? Now I use iptvsmarterspro but the mytv online app is better.
Posts by bartje
What is the benefit off this widevine license for the custommers then?
If I read the specs Netflix should work on this new box in 4K.
From playstore it is not possible to download Netflix because it is not compatible with this box. From marketplace Netflix app is working but quality is very poor. Same as the Z8?
Is it possible to use Netflix, Youtube with 4K resolution on this box or not?
If not why advertising this:
Stream more content and enjoy a higher quality OTT experience with the updated Formuler Z8 Pro. Embedded Widevine Level 1 DRM unlocks access to premium and Ultra High-Definition contents*.
I am testing the box now. First impression is prety much the same as previous z8. Works good and fast but nothing new.
Was hoping that Netflix would work in 4K but netflix app is not compatible with this box is the error in android store. From Market picture on netflix is terrible.
Super. Enjoy
Why not trying powerlines. More stable then WIFI for sure.
Can you confirm you are still having trouble with the newly unboxed devices?
If the problem is persisting right now, please open a support ticket at https://support.formuler.tv so the developers can look into it in more detail.
However, as GreenTurtle has mentioned, I can't reproduce the issue at the moment.
It is solved now, popup showed from the codec and I could press ok and it downloaded en rebooted. This did not work that evening?
Problem with marketplace?
Factory reset the box and set again fresh.
Tried this a few times. Tried also a new box for another customer with the same problem.
Please take care of the problem with the software problem. I have installed almost 10 Z8 boxes allready and was very satissfied but this has to be solved asap. Or another beta release where the problem is solved. I do not want to install 3th party addons to make MOL2 work. It worked perfectly before.
When I disable VOD content it is working and not crashing but indeed when VOD is enabled it want's to download a codec and then it freezes. A few customers with allready a Z8 and the codec allready downloaded don't have this problem.
Hi
I went in to software update.There was a new official update 1.4.14 and MYTVOnline2 7.1.1
I updated to this version and now MOL2 crashes all the time and lot of FHD channels,theres no sound.
I have tried 2 different providers with same result??
Any suggestion?
Same problem here after the update. Tried 2 boxes. Wants to download a codec but then it freezes. Factory reset tried a few times but keeps crashing.
Please an update fast or rollback....
