Posts by TEODORO1962
    hello, since the update, it works pretty well, but some improvements would be welcome, (favorites in vod, several favorites dan tv live with the option to customize the favorites, possibility to have more attractive themes, possibility to personalize the names in the lists .....) thank you for your support and congratulations for your regular work
    Bonjour,
    Moi aussi j'ai eu ce problème avec le même code d'erreur, et aussi une fois que le Z8 est déconnecté et que je dois également redémarrer, j'espère que ce problème sera résolu avec la nouvelle mise à jour à la fin du mois.
    Je voudrais aussi demander s'il serait possible que lorsque je regarde un vod et que je parte quand je n'ai pas fini de regarder, il serait possible pour le lecteur de reprendre sa lecture quand j'aurai cessé de regarder, merci
    yes Sam, for example K**i has the ability to create several groups, and I also think to hide the original groups, not to clutter the list, I think mytvonline is fine but with improvements like this it would be fantastic and easier of use
    hello, would it be possible to have a directory in the VOD to select the movie in VOD to see quickly without having to waste time to search every time the film or series to see, thank you
    would it be possible to have the ability to move the channel that is in the favorites to order by custom category?
    I have a Z8 Formulate
    sorry for my english, i use google translate
