Posts by SevKetchup
    Good evening,
    I have the same problem on the Z alpha and the Z + Neo. by using the integrated player of MTOL2 the vod stops working in a random way sometimes at 20 minutes on certain films and also when I advance quickly or I reverse. The video closes and its returns on the page with the description of the film. with xtream code on the 2 boxes.
    I have the same problem by selecting an external vod player (mxplayer vlc google) as soon as I quickly advance the video, playback stops and returns to the video launch page.
    Thank you for your help.
    Hello I find its amazing the Formuler z8 it does not include Favorites for VOD, it is a basic functionality that needs to be integrated with urgency. Thank you.
    Bonjour je trouve sa incroyable que le formuler z8 n'intègre pas les favoris pour les VOD, c'est une fonctionnalité de base qui doit être intégrée avec urgence. Merci
    Hello. Before testing the beta version I would like to know if it is possible to install the normal version again? And if this is possible how to install the non beta version. Thank you
    Bonjour. Avant de tester la version bêta j'aimerais savoir s'il est possible d'installer à nouveau la version normale ? Et si cela est possible comment installer la version non beta. Merci
