It updated today 2.0.2 and Tizentube supports android 7 again. Also settings button working again.
Posts by Suntu
Download first the new apps i posted and install them.
In smarttube then when you start the app press on your remote to the left and you find menu. Scroll down to bottom and you see settings.
Are you sure its possible to install it on cc?
Iv read that 2.0.1 version requires android 9. Cc has android 7 version.
Display More
TizenTube:
https://github.com/reisxd/TizenTu…/cobalt-arm.apk
Smarttube:
https://github.com/yuliskov/Smart…tube_stable.apk
In both apps in settings you can tuen on automatic updates.
Remove old apps first!
Cant update and cant open settings within the app
Hi. How to update Tizentube on 2.0.1?
.Right now in market is outdated version 1.0.6 and settings are not working in app and it can not be updated to 2.0.1 by itself.
Also smarttube is buffering
like title say. Some rips in VOD ( i assume DV) have this problem. I tried 5 different video players and problen still persist.
i guess IR1. How can i do that?
Hallo. Iv upgraded it from Z7+ and in CC mytvonline 2 cant find option for picture settings.
Is there Imprex engine?
is it possible to turn of epg so that doesnt load at all?
Hi.
Is there a option to turn auto stand by in mytvonline or elsewhere? Or maybe change from 2 to 5 hours.
Thx
well thats stupid
Hi. Title says it all. How can i orginize favorite channels in MyTvOnline so i can arrange the list.
Hi to all. Like titel says in options it wont let me choose 10 bit color...saying 'not supported'.
So i have LG Oled B7 which is 10 bit panel...so am i missing something?
hi. Can you turn of this option? This smooth motion. If so...where?
I dont like this at all.
No. I mean soap opera effect.
HI. Is there a way to turn off True Motion and set desirable value maybe in media player?
