Thank you ![]()
for your responsiveness and taking AFR into account following in particular a feedback I had made.
for the constant developments that make the Z8 one of the best boxes on the market
Thank you ![]()
I did some tests.
The resolution is kept when I first start my video projector (about 10s) or / and the amplifier and lastly the Z8.
In fact the video projector takes about 10s to start and you should
Is it possible that still some option in the "amplifier" and/or projector is doing some sort of "auto config"?
I don't think so, but I'll check tonight
Meaning, did you 100% confirm that both the incoming AND the outgoing ports on the amplifier are "completely" fixed to the 4K resolution? And the incoming port on the projector is also fixed (if possible)?
Which would be confirmed by a "black screen" or "no signal" when connecting a max 1080p output screen to the same port.
Yes the amplifier supports 4K and the video projector too. When I specify on the Z8 the resolution 3840 x 2160 pixels and the colors YUV420 it works with the requested settings. But as soon as I restart the Z8 I fall back to a 1080p resolution and I have to re-indicate the resolution I want: 3840 x 2160 pixels and the colors YUV420
Try disabling "hdmi auto adaptation":
Z8 homescreen > press "RESOLUTION" (button on RCU) > press "BACK" > uncheck "HDMI auto adaptation" > Press "BACK"
Thank you for the quick return but I forgot to specify that this option is of course unchecked ... so the solution is not this
Each time the formuler Z8 is restarted, I lose the resolution and color format configuration (4K Ultra HD, 3840 x 2160 pixels, YUV420).
My configuration is as follows: I have a 4K HDMI amplifier and behind I have a 4K video projector.
I wonder if it is not the order in which my devices are switched on (formulate, 4K amplifier, video projector) which means that I have to reset the resolution and color settings each time.
At each restart I switch back to RGB and 1080p resolution and I have to reset the resolution 3840 x 2160 pixels and the colors YUV420.
Has anyone ever had the same problem?
Do you have a solution ?
EDIT : I have the latest update : Official FW 1.4.53 - SW 7.6.3 (08.01.2020), I had the same problem before the update
Sorry beginning user here PIP is acronym for what ?
PIP : Picture in Picture
The requests for a so called "resume" function should be moved to feature request section.
It is not a request for functionality but a request for correction of a bug
Hello everyone,
When you press twice on the information menu the formuler displays information NET and PIC
What are the values of NET and PIC ?
Thank you
Hello everyone,
Thank you
CodeHello, I am very disappointed that it is not operational in this update to create a list of favorites with VOD and Series. I hope this will be corrected for the next update. Bonjour, je suis très déçu qu'il ne soit pas opérationnel dans cette mise à jour de créer une liste de favoris avec VOD et Séries. J'espère que cela sera corrigé pour la prochaine mise à jour.
I support this request
