Posts by John Kain
    For the information that I got, there aren't yet software in the market that support series and radio channels after the changes of September 19th.
    So until that no series... unfortunately. I don't know if this information is general to all providers or only for specific ones.
    Hello, blackking
    Your provide should be right. Try to test the beta version of MOL. You can check my message in the “black screen” topic:
    “Hello, everyone
    As SAM said the beta version of MOL2 is available.
    In the MOL2 beta version everything works fine and as expected.
    I didn’t test yet in the MOL1 beta version (if it is available. It’s suppose be available only at the end of this week).
    For the information that I’ve got new versions of MOL are expected to arrived:
    - MOL 1 - in the end of this month. In two weeks, maybe;
    - MOL 2 - next week.
    Thanks to Formuler Support for all the explanation. Excellent service support... and products, of course.”
    I can’t use via MAC address with actual release of MOL, but with the beta version it really works normally and as expected.
    P.S.: MOL1 beta should be release until the end of this week.
    Hello, everyone
    hello,
    Has anyone had problems with MyTVOnline using the portal/Mac address since September 18/19?
    In both a z8 and z7 + I can not see anything.
    On z7, using the MyTVOnline, everytime I try to launch the service via portal/Mac address, MOL crash and ask to reopen it, creating an infinite loop.
    In the Z8 is even worse because it completely crash the box when arrive to 99 or 100% when boot the IPTV service.
    SAM
    Did you any feedback similar to this on this days?
    If necessary I can share a video showing this situation.
    Thanks.
    PS: Note that the same service on a MAG256 Wi-Fi works normally, so the service itself is not malfunctioning.
    I am having also some issues about the internet connection via Ethernet.
    My problem is the following: after standby the Z8 I can't reconnect it to the Internet (via RJ45 Ethernet cable). I always have to reboot it. A workaround that I found is configure the on/off button from the remote control to Shutdown the box, but even using this workaround aften after a while (some hours, for example) the Internet connection is disabled.
    I already notice this issue before the last update, but I was expecting that it will be corrected in the last one, what didn't happen.
    Resuming, after a standby mode Internet access is disabled in my Z8 box.
    I don't know if SAM, or someone from Formuler knows about that issues regarding the Z8 and Internet connection.
    SAM if you need some more info from my side ask, ok?
