Timeshift is on, no EPG timer set, even if the show still in progress, I'm canceling the recording but it is locked to that show/channel, the small red dot still showing on the channel and no data was recorded.
Posts by kattan
Hi Sam, hope you are doing fine.
every time I press to record a show, it locks the channel, meaning i can't flip to another channel, it keeps going back to the recorded channel after 30 sec. even after recording is done.
I had to disconnect the portal, unplug box, router and modem and reconnect all again, seems only this way I can get rid of the recording mode.
any idea why this is happing to me. I stopped using recording bcz of this issue.
SAM, it worked! you awesome! Thank you.
Thanks SAM, I will and will let you know
can do that from a laptop or it had to be from the TV box?
Hi amovie,
I'm not using the internal storage to recored, I'm using the USB.
after recording I checked both and both are empty.
thx
Hi CodeIT,
I did apply the latest update for the z8, end of march.
time shift is ON and working on some channels though.
Kensington 64 GB USB 3 stick.
ExFAT, disk utility through my mac.
thx
Hello, it seams everyone can record, no problem, I can't!
z8 recognize the USB when I go to Setting/storage
tested the schedule recording, it came up on time, saying it is recording and when it is done, can't find it the recording, EMPTY!
when trying to test recording on the a channel when it is on by pressing the record button, massage appears asking to close live TV!
I'm i doing anything wrong?
appreciate your help and comments, thanks
