People i got it. And it works. Thank you very much
Posts by Izzy
Ya but try connecting via the XC API URL. You can still connect on many devices, but Z7+ allows you to connect via XC API instead of M3U URL
can someone explain to me how you do this please? To connect via Xc api
i try to connect with m3u url, cause i use the url on different devices.
Check if your line works on another device or app, just to be 100% sure that it's not from providers side.
Mevi, i have the same problem as Olympus. if i put my m3u link in my tv online it says channel list empty. With different another apps it works fine(perfect player,..) i got a m3u_plus in my link and with my online tv is that a problem, if i delete _plus from my link it opens all channels but not the groups. With another app it works fine and all groups can open. I think the problem is in the my online tv app
Olympus, have you solved the problem? I have the same problem here, my m3u works with perfect player app or another app but my online tv says channel list empty, somebody else that solved the problem?
