I'm pleased to hear I'm not alone with catch-up being 1 hour out of sync on the Z11 since the change of clocks.
I'll let my service provider know it's a Z11 issue and, hopefully, we will get a fix soon!
Hi Sam
You can't set EPG into UTC mode on a Z11 Pro running TVOL3 can you? I've been trying to find the setting but can't?
I've set the time manually and checked it's set to GMT but catch-up is still 1 hour out even though the EPG is correct.
Have you any further ideas?
There is an EPG setting called Alternate (rather than Normal) which I could select when adding a content provider - would that help?
Just clutching at straws really as everything was fine until the clocks changed!
No I don't use a VPN and given my provider works fine on both the Z8 and their Android phone client makes me think it's a Z11 / TVOnline3 problem / bug.
My son in law has the same issue with the same provider in his Z11 ....
It would be good to get a comment from someone in Formuler Technical support
The EPG is correct though - if I change the EPG Offset then the timings on the EPG becomes offset and are therefore incorrect
Basically it looks like the wrong file is being played in catch up - so rather than playing the file timed 1800 for the 6 o'clock news .... It's playing the clock tined 7 o'clock
Since we changed the clocks - I've been having problems with catch up TV on my Z11 box (my Z8 is working fine though).
EPG is totally aligned to the programs I am watching so 6 o'clock news is shown as starting at 6 o'clock.
However - if I try and watch the 6 o'clock news via catch-up - I am shown the TV program that occured at 7 o'clock
So even though the EPG is totally correct (and has been refreshed many times and is not offset in any way) - catch up seems to be selecting the wrong file to playback.
So to watch the 6 o'clock news I've got to select a program from the EPG that was broadcast at 5 o'clock.
Catch-up is basically one hour different to the EPG!
Any thoughts?
Mark
When I watch IPTV via my Android App (on my tablet) then I can refresh the list of channels (by selecting a menu option).
However - I can't seem to find this feature on the Z8. I have found how to clear the EPG data .... but not a way to refresh the channel list.
The only way I've so far found to fix this is to restart the Z8 or set the Power Option to OFF so that the Z8 restarts everytime I switch it off.
Anyone got any ideas how I can reload the channel list without restarting the Z8?
TIA
Trenners
