Posts by Pags
    I switched to using MAC connection. This somehow seemed to have helped.
    USB-Storage was already formated with rufus, as per guide.
    I think the reason is the buffering of Full HD channels. I noticed when I schedule HD channels it's working fine.
    Only the Full HD channels are causing this issue. They started recording now, but dropped after some time.
    But I found this to be an issue here on the forum even before the beta.
    I'm checking with my provider if this is on their side. Usually for Full HD channels I start to timeshift for 1 minute to prevent any buffering, which is not possible for scheduled recordings, but solves the issue if I live watch it.
    Anyway many thanks for the response
    hi everbody,
    I'm a new user of the zx 5g. Very happy with it in general. Updated to the beta, as my favs got mixed up basically after every boot. I now ran into an issue, that scheduled recordings are not starting. I select multiple shows or movies overnight. On different channels, time is not overlapping. Next morning i have no recordings. I tested this today. I scheduled a show 5 minutes before the start. Recording never started for some reason. I even was on the right channel, not in stb. Are there issues with scheduling over epg? General/manual recording is working fine. Or is there a problem if i schedule multiple channels (after each other, not at the same time). Many thanks and keep up the good work
