Why we need to do always a manuel refresh for the content source, can you not make it automatic when we start the app ?
Posts by oliwal
I want to see a "Refresh button" on the home page of the MyTvOnline+ app.
Having to go into "Content sources" feels unnecessary and cumbersome.
An "Update button" would also be good in the settings menu of the MyTVOnline3 app.
Still no automatic content refresh when we start th application ?
I can't seem to see the (export portal details to MYTVOnline+ mobile app)
It's not implemented on the app yet. An update will follow soon.
Hello, after update to FormulerZ11ProMax with MOL3 I have many channels that no longer work and the screen remains black. The channels work very well on Tivimate and Smarters on the same box. Is ther a solution ?
v111.2.2-3055 beta installed
are you using xtremecode, mac or m3u?
also try:
1. ensure refresh is up to date(if there is a refresh when the menu is press, activate it)
2. try updating to the firmware beta 11.2.2
3. use xtremecode if using m3u/mac
Thanks, update do beta 11.2.2 and deleting and recreating portal solved my problem, thanks!
I have a lot of missing channels in different groups on Formuler Z11 ProMax MOL3, while with the same server and config it's all ok on my old Formuler Z8. Is there a solution to this problem?
Thanks Oli
Why not soon a model sat E2 with MOL2, looking at various forums it would be a hit ?
Hello, I absolutely need an extra Formuler box because I just bought a new crazy 86" TV and without MOL2 it will be useless!
The Formuler boxes are simply the best!
My Number: 382
Hello, I have some troubles with Cloud Timeshift Icon.
Sometimes the icon is not on display (action bar) directly, if i press settings icon (red button) and then come back to action bar the Cloud Icon appears !
Is there another solution ? Thanks.
I have installed 4 devices (Formuler Z8) in the same Week-End with the same provider and only one Z8 have also this issue. Please find a solution, as already said we want to use MTVOL2 an no other stuff, that's why I buy all these devices ! Thanks.
