In the App section of the Main Screen, installed apps are displayed but not all of them. How do I add an installed app to the ones that are displayed. I have a particular app installed that is not displaced and only can be opened by going to Settings-Apps-the Specific Installed App and then selecting Open for that App.
Posts by joe184
I have the same problem. When I was using an Amazon TV Cube player, pressing the Home Button on the Amazon Remote would automatically switch the Samsung TV to the correct TV input for the Cube. I also have an Apple TV player and when I press the Menu button on the Apple TV remote the TV switches to the correct input. My Z8 CEC is turned on. I used the same cable I connected the Cube to the TV for the Z+8 and I also tried a new Active 2.0 HDMI Cable connecting each end as directed. Is Formuler Z+8 tech support working on a solution? At this time, the work around has been to program the source button on the Formuler remote to switch from input to the Formuler Z+8 input.
Really simple when you know what to do. Thank you very much for your help with this and a previous question. I will sleep better tonight not having to think of a solution,
Joe
I recently changed my Google Mail PW using a computer. Now when I try to access the Google Store site, it asks me to sign-in. I have been unable to locate a place where I can sign-in with the new password. The places where I have looked are as follows, the opening page of the Google Play Store app, in the Google Store Menu-(Account and Settings), & Formuler Settings for individual apps. The app does recognize my email address.
I wanted to delete the Google Play Store app and then reload the app in hope I could start anew. However, I could not uninstall the Goggle App using the uninstall command for that app. I restarted the player after the uninstall command but the App was still present.
Where do I sign-in with my updated password?
How do you upgrade user downloaded apps to their latest version, example Prime Video?
