Anyone can help?
Posts by pete1919
Hey everyone!
Whenever I click the power button on my remote and come back to watch TV the date and time gets reset.
Any ideas how to fix this? Am I factory resetting each time I power the box?
With this method, you’re purchasing an m3u subscription from your reseller and not a m*g subscription correct? Also the username and password are the same that my provider gives me?
I'm currently using XE & m*g because it offers catch-up. It's currently the best option if you use XE & MOL2. But m*g can not use more than 1 connection (it's a m*g limitation and nothing to do with either XE or MOL2).
I would prefer to use M3U with XE as it normally allows you to use more than 1 connection (ie watch & record separate channels, but not currently available in MOL2). I also find that the tv guide loads much faster using the m3u/xmltv system. Also no catch-up currently available via m3u on MOL2.
XC Api allows catch-up, time-shift, more than 1 connection (but not currently via mol2), extra information about your line (subscription length). But it can't be used in conjunction with XE as XE does not provide a username & password.
I suppose if you could fully edit groups and channels in MOL2 then XC Api would be a great method if your providers own tv guide was any way half-decent. There would be no real need to use XE in that case.
Have you been able to use portal through xtream editor? Not sure what info i put in to the portal area as xtream editor provides me with nothing
You're Welcome
Well smack me in the mouth with a wet fish!.....I never knew that could be done in MTOL, just tried it & it works 100%, pulls in everything including live tv,epg & catchup,...even VOD, just needed to enter the relevant info from my m3u line & bingo,....many thanks
hey! where do you pull the relevant info from to get it to work on portal? do i use xtream editor the EPG URL and M3U URL? what exact info do i need from there to plug in to portal on MOL2
Display More
What is the new portal url and username/password that I get from xtream editor?
Heres what im doing
1. go on xtream editor
2. Put in provider portal, username, and password
3. Edit playlists
4. Where do I find new portal url and password and username?
How do you find the new portal
You have guide on their website.
Can you please tell me where I find the new portal url, username and password. Ive been trying to do this for months. I can only find EPG URL and m3u Url. No portal url, username or password.
yessss
Heres what im doing
3. Edit playlists
Is there any way to edit channels on xtream editor and then watch tv on portal using XC Api with the edited playlists?
What if I buy an m3u that allows for 2 connections? Then would 2 connections at the same time on portal be fine?
I have multiple TVs though not just one
So to do this, do I purchase a m3u or a Mac subscription from my provider?
HELP! Can someone tell me how to get catchup while using m3u on mytvonline 2 on my Formuler Z8.
Thanks in advance!
Hey,
I register my IPTV through Xtream Editor and set it up as a M*G. However, when I go to MOL 2 and use the URL : http://m*g.xtream-editor.com/mol all of my channels are black. But, I can see the edits to the playlists I made. Ive also tried adding the username and password in addition to the URL but still not working..
Any ideas?
Anyone know if I can have multiple M*Gs in Xtream-Editor and if they charge per M*G line or is it a one time fee?
Thanks, however, I was using M3U links to begin with.. never used an API
Hi there, I have been using xtream editor links with multiple providers on MOL 2 for several months but today I suddenly get a black screen. I am able to connect via direct provider links but not with xtream editor links. Futhermore, apps like Tivimate work with my xtream editor links. Please help me! Also if you know of any similar sites like xtream-editor or anything that I can remove channels with, would be of great help. Thanks everybody!
Are there reported issues with Portal also or just M3U?
If I use other tv stream apps will i get ip banned?
Yup i ised new beta
When will the provider IP Ban be fixed? Have had to switch providers 3 times, only to get banned by each. I connect and in a few minutes I get a black screen on all channels. Then have to talk to my provider and wait for an unban.
Also, is this just a MOL2 issue or an issue in the Z8 hardware? Will other iptv apps work? And if so any recommendations?
If i connect with xtream codes on MOL 2 m3u will catch up work?
Hey guys, does anybody have an idea when we will be able to have catchup with m3u links on MOL2? Also if im stuck with MAC what do you guys use to edit MAC playlists for use on MOL2?
