Posts by mataia
    how to give static IP?
    The Internet-Box Nord individual expert settings in the area of network and IP addresses. To change these settings, enter "http: // internetbox" or "192.168.1.1" in our Internet browser and log in with your Internetbox administrator password. Switch to expert mode and switch to the "IP settings" tab via the network point. Under "Can assign a static IP address" you can assign a static IP address to a device.
    Set up on the end devices:
    The static IP address can also be configured on the network device. However, I recommend creating all static IP addresses centrally in the Internet-Box web portal, because manually configured network installations require expert knowledge and planning. When selecting the static IP address in the end device, avoid the addresses from the range 192.168.1.101-192.168.1.168 (DHCP range of the Internet Box).
    Important: Please make sure that you use the same static IP address only once. It is also advisable to set up the device either only on the router or on the end device itself. Otherwise, you risk IP conflicts that prevent Internet access.
    Googled source
    As a supplement; my access is via ID.
    Since the update, the download speed of the Internet line is sometimes half high / + - 400 Mbps with LAN.
    Usually it is at + - 700 Mbps with LAN.
    My router is from a telecommunications provider.
    LAN connection with a multimedia network distributor in the apartment.
    The fiber box (router) is based on the ultra-fast glass fiber technology - XGS-PON / OTO connection.
    Is my router blocking something?
    Please test same scenario with app like Tivimate and check if issue happens. Try also to use other connection wifi <> ethernet.
    Didn't find the Tivimate app, not even in the market. For this, the app IPTV SMARTERS installed and logged in with the Xtream Codes API. It is of course not qualitatively comparable with mytvonline2, but it doesn't have the same problems as connection crash ... black screen and no restart necessary.
    LAN and WLAN make no difference.
    Is there a new software update in sight? who fix these bugs ?! So the box is unusable! :tired_face:
    Hello everybody
    I am new here, I have a Z8. Since the update I zap after 1-2x, a black screen ..... it seems that the connection breaks down. Vod and series also do not open. But depending on the transmitter, it reconnects after 20-45 seconds.
    Speed test result with LAN is 400-500 Mbps.
    I cleared mytvonline2 cache yesterday, disconnected Z8 from the network and reconnected after a few minutes ... problem still there. Then I reset to factory settings.
    Everything is restored, unfortunately mytvonline2 can only be downloaded with the latest software update .... very annoying. Didn't use anything. Problem still exists
    I'm in contact with the provider .... he also has a Z8 with SW update ... he has no problems. He doesn't know what is blocking.
    I'm desperate ... I'm very grateful for any help.
    I speak German .....
    Sorry about my english .... Google.
