Excuse me, that I'll answer you now. I've been watching myself switch channels while the channel is switched off. I have to reboot and reconnect to the provider via My TV online 2. And that does not always work
Posts by Pitbull
Sam,
First of all thank you for trying to help me.
I have the Softaware 7.2.2 on it. I have already assigned an Ip to the Formuler Z8 and set the DNS1 to 8.8.8.8. I have already switched off the Ipv6. I have a Connect Box as a router, whether that is probably in it? I do not have as many settings as in a Fritzbox. Have already been added to the Connectbox the FOrmuler Z8 on reserved rule. -
Then it's good. :-))
yes, I've tried it with Epthernet and cable. I'm still connected with cable, it does not matter if I connect it via WiFi or Ethernet cable. It's the same problem, sometimes it sometimes works fine for a couple of days or sometimes not at all. I have your guide "How to use MAC / ID portal, Xtrema Codes Api (XC) and M3U Url on Formuler Boxes." read and synonymous with me in the receiver inserted. I have tried 2 options, once on Xtrema Codes Api and once on the M3U Url. Both times the same problem. I am desperate why this could be. -
Sorry my English is not so good. So please forgive me my mistakes in case I am wrong. Thank Uncle Google.
I know what you mean. No, it's not green. My internet connection works but perfectly. I can also play everything else with other apps on the Formuler Z8. Just the Mytv online 2 connects once again not with the provider. My app GSE on the phone does not work via Wi-Fi to play the broadcasts. But as soon as I go on mobile data, so do not use WiFi, it works on the phone and I can see all the stream.
Was ich nicht genau weiss, ist das ich bei Add Play list die ganz lange http:// .....................................ts eingegeben habe. Und sie ist ja auch gelaufen, bloss nach einer Zeit wird alles dunkel. Komischerweise läuft es aber auf meinem Handy mit GSE App.
Hallo, ich habe mich einmal über Add Portal connected und das andere mal über Add Play list. Habe beide Optionen von meinem Provider erhalten gehabt.
Guten Tag,
bin neu hier, habe mir vor kurzem eine Formuler Z8 zugelegt. Habe aber das Problem das meine Verbindung zum Portal immer wieder ohne Grund abbricht.
Sie läuft teilweise 2 Tage ohne Probleme und dann ohne Grund wieder einfach alles weg. Meine Internetleitung funktioniert einwandfrei. Ich habe auch die GSE App auf meinem Handy drauf.
Dort ist mir aufgefallen das auch mit meiner Wlan Empfang ich die Programme nicht zum laufen bekomme. Sobald ich aber auf dem Handy auf Mobile Daten wechsle , funktioniert das
wieder einwandfrei, bloss nicht auf meiner Formuler Z8. Komischerweise funktionieren aber alle anderen Apps auf der Formuler.
Ich weiss das dieses Thema öfters hier anscheinend behandelt wurde, trotzdem bitte ich euch wiederum um Hilfe. Komme einfach nicht mehr weiter. Ich habe auch das gleiche Problem wenn
ich die m3u Liste per Fernbedienung in die Portal list eintrage. Sie funktioniert, dann wieder ohne Grund geht die Verbindung weg. Ich benutze als Router eine Connectbox. Habe meiner Formuler Box eine iP Adresse zugewiesen und dann auf der Connect Box zu Reservierte Regeln hinzugefügt.
