ouch so the tvg-shift="-1" is useless?
Posts by davex
hi,
one question, formuler accepts the epg shift per channel?
for some channel it have 1 hour more and i want to shift 1 hour, its possible do it for an specific channel and not entire epg?
regards
i have the same issue about internet and !
also mytvapp crash in that moment i havent internet, so i reboot the device and everything for now is working fine.
why dont come with a microsd ?
please fix this serious bugs!!!
EPG DIDNT WORK:
MISSING GROUPS, VOD AND CHANNELS
CodeTHIS NOT WORKING #EXTINF:0 tvg-name="Sobrenatural S02 E11" tvg-logo="http://xxxxx.jpg" tvg-id="" group-title="SERIES",Sobrenatural S02 E11 http://XXXXX.mp4 THIS WORKING #EXTINF:0 tvg-id="" tvg-name="Sobrenatural S02 E11" tvg-logo="http://xxxxx.jpg" group-title="SERIES",Sobrenatural S02 E11 http://xxxxxxx.mp4hope you can fix it asap because its really serious
well i found the problem.. its a key sensitive issue.
this not working
tvg-id=
this working
tvg-ID=
the entire epg in other program the epg link works perfect but on formuler it didnt show any information.
i create a ticket and submit the epg link and they told me its fixed on this version, but i still have no epg...
well i create the support ticket and i provide the epg link, they told me its fixed on this version but still not!!
i can help with spanish
Will ask the developers to look into this
thanks!
- Formuler model Z8
- MYTVOnline version 7.5.6-1638
hi,
i have an issue with not parsing correct the epg and vod images, i show you the example
THIS NOT WORKING
THIS WORKING
the formuler cant parse the tvg-id if not after the extinf....
please can you fix it?
regards and happy new year
thanks for reply!
hi!
i have a problem two problem with the epg link.
1. in some redirect it didnt download the file and stuck in epg loading.
2. with other link it download, show the epg but stuck in epg loading.
if possible by dm can i send both link so you can see the problem?
thanks and regards!
hi all,
i want to suggest two features.
1. possibility to have dual audio output on PiP one the normal output and the other using a bluetooth
2. a reminder when the playlist will be expired, like 3 days before
regards
thanks for reply,
i send the information by pm, if you need something else to help please tell me.
regards.
my provider have a groups with special character that doesnt show on mytvonline here is an example
● SPORTS
i saw all the groups channels except those with this special character.
regards.
