This didn't work for me! Still stuck on my old and broken version of 6.3. I got the following in Terminal. Any ideas?
zgemmah9s login: root
root@zgemmah9s:~# wget --no-check-certificate -O installatv.sh installatv.sh
atv.sh?dl=1 && bash installatv.sh
--2019-10-11 18:31:35-- https://www.dropbox.com/s/nqbo698rxconave/installatv.sh?dl=1
Resolving https://www.dropbox.com/... 2620:100:6020:1::a27d:4001, 162.125.64.1
Connecting to http://www.dropbox.com|2620:100:6020:1::a27d:4001|:443... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: /s/dl/nqbo698rxconave/installatv.sh [following]
--2019-10-11 18:31:36-- https://www.dropbox.com/s/dl/nqbo698rxconave/installatv.sh
Reusing existing connection to [http://www.dropbox.com]:443.
HTTP request sent, awaiting response... 302 Found
Location: https://uc153997689718910807f72b1d37.dl.dropboxusercontent.com/cd/0/get/AqNxr…RjvDAvUs_NXi4io
Hq9ZcELwWw8XM8EbpMy2HRAvXN3tjR0OtRYDK8GZkq-T8IoqBXNz_V-wFQ5U2wGyQEYmOmqSsqyECOSg/file?dl=1# [following]
--2019-10-11 18:31:36-- https://uc153997689718910807f72b1d37.dl.dropboxusercontent.com/cd/0/get/AqNxrwzpfBev9_d
RjvDAvUs_NXi4ioHq9ZcELwWw8XM8EbpMy2HRAvXN3tjR0OtRYDK8GZkq-T8IoqBXNz_V-wFQ5U2wGyQEYmOmqSsqyECOSg/file?dl=1
Resolving uc153997689718910807f72b1d37.dl.dropboxusercontent.com... 2620:100:6020:6::a27d:4006, 162.125.64.6
Connecting to uc153997689718910807f72b1d37.dl.dropboxusercontent.com|2620:100:6020:6::a27d:4006|:443... connecte
d.
HTTP request sent, awaiting response... 200 OK
Length: 896 [application/binary]
Saving to: ‘installatv.sh’
installatv.sh 100%[===========================================>] 896 --.-KB/s in 0s
2019-10-11 18:31:37 (11.4 MB/s) - ‘installatv.sh’ saved [896/896]
You are about to flash your zgemmah9s box with the latest stable image of ATV
If using multiboot box please enter partition to flash:
--2019-10-11 18:31:48-- http://images.mynonpublic.com/openatv/curren…mah9s-20191010_
usb.zip
Resolving images.mynonpublic.com... 176.9.45.237, 136.243.69.212
Connecting to images.mynonpublic.com|176.9.45.237|:80... connected.
Length: 214547027 (205M) [application/zip]
Saving to: ‘latestatv’
latestatv 100%[===========================================>] 204.61M 837KB/s in 7m 17s
2019-10-11 18:39:06 (479 KB/s) - ‘latestatv’ saved [214547027/214547027]
Archive: latestatv.zip
inflating: bootargs.bin
inflating: fastboot.bin
creating: h9/
inflating: h9/imageversion
inflating: h9/bootargs.bin
inflating: h9/rootfs.ubi
inflating: h9/noforce
inflating: h9/logo.img
inflating: h9/pq_param.bin
inflating: h9/rootfs.tar.bz2
inflating: h9/fastboot.bin
inflating: h9/baseparam.img
inflating: h9/uImage
ofgwrite Utility v4.5.5
Author: Betacentauri
Based upon: mtd-utils-native-1.5.1 and busybox 1.24.1
Use at your own risk! Make always a backup before use!
Don't use it if you use multiple ubi volumes in ubi layer!
Flashing rootfs
Flashing kernel
Searching image files in ./ resolved to /media/hdd/atvimage/h9
Found rootfs file: /media/hdd/atvimage/h9/rootfs.ubi
Found rootfs file: /media/hdd/atvimage/h9/rootfs.tar.bz2
Found kernel file: /media/hdd/atvimage/h9/uImage
Found UBIFS rootfs
Found mounted /newroot
Found mountpoint for rootfs file: /media/hdd
Found /proc/mtd entries:
Device: Size: Erasesize: Name: Image:
mtd0: 00100000 00020000 "boot"
mtd1: 00100000 00020000 "bootargs"
mtd2: 00100000 00020000 "baseparam"
mtd3: 00100000 00020000 "pqparam"
mtd4: 00100000 00020000 "logo"
mtd5: 00100000 00020000 "deviceinfo"
mtd6: 01000000 00020000 "kernel" -> /media/hdd/atvimage/h9/uImage
mtd7: 0ea00000 00020000 "rootfs" -> /media/hdd/atvimage/h9/rootfs.tar.bz2
Using kernel mtd device: /dev/mtd6
Using rootfs mtd device: /dev/mtd7
killall: CCcam: no process killed
Usage:
kill [options] <pid> [...]
Options:
<pid> [...] send signal to every <pid> listed
-<signal>, -s, --signal <signal>
specify the <signal> to be sent
-l, --list=[<signal>] list all signal names, or convert one to a name
-L, --table list all signal names in a nice table
-h, --help display this help and exit
-V, --version output version information and exit
For more details see kill(1).
Usage:
Options:
killall: kodi.bin: no process killed
killall: hddtemp: no process killed
killall: transmission-daemon: no process killed
killall: openvpn: no process killed
sh: /etc/init.d/sabnzbd: No such file or directory
Stopping automount: done.
Syncing filesystem
daemonize
successful
start umount_rootfs
root@zgemmah9s:~# cp: can't stat '/lib/libcrypt*': No such file or directory
Switching to user mode 2
Session closed.
