I am wandering why it disappeared...It the a software or hardware problem?
Posts by mdb
Since a few weeks my Z8 does not see the 2.4ghz wifi network. It works great on 5.0 ghz. I restarted the box and the router and nothing changed. Both networks are working on other equipment. Any idea?
Which replacement remote should I buy for my Z8, BT1 or IR1? Regards
On my Z8, I tested one with a micro SD in it and no luck.
Thanks ddd 👍🙋🏻♂️
SAM, YES, the Timeshift was off ! I don’t since when and why...Everything is good now. Thanks and regards.
I have a Z8 and the the Timeshift functions, pause, etc are not working. The recording is working ok. What is the problem? Tried different usb flash drives, problem is the same.
Finally was able to download MOL2 from Market. I deleted and re-install the portal. MOL2 is up and running good again. Thanks Sam
Thanks Sam for helping me!
I tried on Market and It gives me a Download Error message...
I has to uninstall Mytvonline 2 from my box because I had problems. How can I re-install a clean version?
