Posts by Peter Ch.
    In case others have the same problem, MyTVOnline now has an additional entry under Portals.
    Instead of entering an .m3u playlist link under Portals (which no longer works) you have to select Portals->Playlist and enter the link (or USB file) there.
    Deleted second picture (provider url shown - not allowed here).
    If i saw it right you use Stalker with registered ID, right? Please check now the URL you got from your provider and compare with the included in MOL.
    Check if it is "http" or really "https" like you did insert.
    Btw. the url looks wired and not standard type like from other providers..
    I'm sorry I posted a screenshot that is not allowed. I didn't realize that.
    You do not need any credentials whatsoever. I don't know if the url is blocked in other countries, but here it also works from other local providers.
    SAM please could you try the url. I very much suspect it should work for you, so long you have an older version of MyTVOnline.
    All you need to do is enter the url (yes, "https" is correct) and that's it. I also have an address from a different local provider and it also worked with version v1.09.92-r2521 but not with 1.9.98.
    I have no idea if the url is wired or not standard or whatever - fact is it no longer works with v1.9.98.
    BTW, I believe the firmware was also updated when I did the update - if that matters.
    As soon as I select MyTVOnline I get the following message:
    I cannot and have not entered anything in MyTVOnline settings yet. MyTVOnline is virgin since I've done a Firmware and Software reset many times in my attempts to downgrade/get the app working again.
    The same settings worked perfectly before I updated. They also work perfectly on my friend's Z7.
    This is very frustrating...
    So I'm stuck with a useless box? That can't be?
    A friend of mine has a Z7 with an older version of MyTVOnline. How can I copy his to my ZX?
    Without a functional version of MyTVOnline my ZX is absolutely useless. As you can imagine, I am not at all happy with this philosophy, to put it politely.
    I really hope someone can help me...
    I foolishly updated my ZX and now have MyTVOnline v1.9.98. This doesn't work.
    I always get the text that the portal is incorrect or no internet connection.
    How can I download a previous version? I have tried the 0227 trick (Choose MYTVOnline version), but the only version available is 1.9.98.
    I have done a factory reset, a software reset, installed 1.9.98 and used the 0227 trick, uninstalled 1.9.98 and used the 0227 trick but nowhere can I find a previous version.
    My previous version was v1.09.92-r2521 and this worked perfectly.
