Just wanted to report back on the issue I was having. After digging around a bit more (and looking at the AP log files, and not just the router log files) I found that my access point is likely what was causing the issue. I started monitoring both the router and AP and saw that the AP was dropping/disconnecting all clients intermittently - all other clients (phones, laptops, tablets, TVs, Firesticks, etc.) automatically re-connect after a second or two so I had not noticed the issue until I started using the Z8, which does not automatically re-connect. I updated my outdated AP firmware and have not seen the drop/disconnect issues now for 48+ hours. Will report back after I monitor the issue a while longer. Thank you ddd for you responses.
Posts by pmrls
I took a look at the log files and did not see anything that stood out (to me, I am a novice w/networking); I did notice my time setting on the router was not correct so I have fixed that and will keep monitoring and try to correlate the issue now that the time is correct. It is an intermittent issue so I will report back when I get a better idea of when/how the issue is happening. More info about my hardware: Ubiquiti Edgerouter X using an ap (AP-LR) for wifi.
I am having a similar issue to Op where Z8 is still connected to Wifi but losing internet connection. I can simply either toggle Wifi off/on or switch from 2.4GHz to 5GHz (or either way) and this re-establishes internet connection. I have set a static route for the Z8 with no help. Any tips would be appreciated. I tried a power line adaptor connection but the connection to use ethernet but connection was too slow in my setup and unusable for streaming.
