More info is needed. Check PM.
Thank you for your quick response.
It seems I've solved the problem. Apparently it wasn't the update. It was just a stupid coincidence.
I noticed that the error I mentioned always occurred after about 30 minutes... In the end I replaced the USB stick that I was using for timeshift. And since then everything has been running smoothly again.
