Since my isp upgraded my router to a new one HG8247X6-8N.
I cant access wireless 5ghz no more.
Tried everything.
What is the problem?
Can't you launch and firmware upgrade, that really matter?
Tried everything.
Z alpha box doesn't start.
I connect yhe power cord but it doesnt start, doesn't show z alpha logo or android logo. Doesnt go red light. It keeps on white light and shows no signal.
Please help.
Already done a factory reset by the box.
Thanks for the answer mevi.
But we buy a box and it doesnt work?! We have to buy extra parts?
This isnt fair...
I ve always used z8 in living room cable network.
Fiber 200mb.no problems.
When i brought the z8 to bedroom and tried to connect it wireless its a nightmare. Speeds ridicoulsly slow.
With my smartphone i can get 200mb no worries in 5ghz network.
With z8 never pass 30mb.
Its awful.
Already put it in static ip. Fabric reseted it.
Nothing.
For a 140€ box this is a joke. Should have bought a box M@G instead... 😪😪😪
Same here.
With the last firmware was perfect.
With the last one is constantly blacking out for seconds.
Tested my line with smartiptv and is flawless for hours.
What a hell?
I bought a 140€ top of the line iptv box and the experience is horrible constantly blacking out... Wtf?,
Smartiptb cost me 5€ for Life.
Correct this asap.
Hello, since my last update, my z8 uaing mytvonline2 goes black for 2 seconds, then continues playing, then goes black again for 2 sec.
Whats happening?
Changed the port hdmi already and still no luck. Can you help me?
You are completely right.
It costs 5€ for life.
After a month of using the formuler z8.
My final conclusion is that the quality picture on the smart iptv app (which is free by the way) is far better than the z8 box which cost me 114€.
I've tried everything to improve quality... But with no success.
For VOD AND SERIES AND LOGOS AND ORGANISED channels obviously this is a better solution, but for the image quality...
I have the same problem.
Did you fix it already?
I belive is b) and d) options.
What can i do?
1. Yes
2. 2160 60p
3. 1920-1080i fhd
4. 2.0
Hello maker08,
I'm with the same problems.
I've bought this z8 box expecting the best quality.
But i'm getting best quality with smart iptv app (which cost me 5€), and the box 114€ 🤨
With the same server.
Any help will be great apreciated.
I'm using the smart iptv to see the games, because the quality is better...
And have the formuler turned off... 😭
