hello, sam I tested a few things and it works I can leave it like that or there is a risk of hacking of my network in fact I put on the wired connection ip address that I had when I was in wifi and I disabled the wifi it is surely my router which created this address. thank you very much
Posts by volpe fernando
non à côté Belgique
sorry sir for posting in the wrong place. for the rest I am not technical enough for network configuration I will get help and then I come back to you to inform you this will not be immediately because there is the confinement of the population following the coronovirus 19 again thank you sam
hello, I have a form z + recently it disconnects often and now it does not want to connect at all my supplier tells me that on his side everything and good and I think so, because when I want to connect with MYTVONLINEv1.9.94 it stay a while and then tell me connection problem please check your internet connection but on the box youtube works as well as google I think it is the box which does not find the portal I did factory reset software reset several times I I even did a recovery facinit via usb but still the same message while I have the other applications that go on the internet.
The MYTVONLINE v1.9.94 application is put by default on startup by me in the system.
I even tried wifi without the internet cable but still the same message.
After 24 hours off I restarted and it connected to the portal slowly and I knew how to have the channels but the management of putting the favorites worked at the beginning but then I had to leave the group of channels for what then put in memory image freeze I changed the channel I had the sound of the channel that I had just put but still the frozen image of the other channel and that on all the channels I changed I tried by changing group cinema chain but still frozen images of the beginning and sound of the chain put.
So even by putting the standby I turn on again and it returns to the frozen screen from the start I decide to restart with the remote control (stb) but now it does not want to connect to the portal this box worked well before the last software update and Mytvonline.
Formulate Z +
Retail box
app version iptv v1.09.94-r2540 - January 14, 2020
s / w version v2.8.96 - March 06, 2020
s / w revision r23219
Z_PLUS model
Here are some photos.
https://www.dropbox.com/s/i7kgwo8j25wud8i/IMG_6790.JPG?dl=0
This is if someone can help me I thank him in advance
volpe fernando
