I tried that with two different USB drives and it backs up but the other device doesn’t pickup the backup file from drive. It recognizes the drive (as I can record to it) but the backup is not there on the device. It shows up on the other one.
Posts by Ryan_J_C
Since updating to the latest version of firmware, there is a glitch when in your favorites group and entering a direct channel number. For example, when in favorites, if you enter channel “4”, a zero gets added to the end, and it changes to channel 40 instead of 4. Channel 5 goes to 50, even channel 12 goes to channel 120. Formuler support replied to me asking if I’m sure my favorites has a channel 4...come on, I have two z8 boxes and only did the update on one of them. The non-updated one works as intended (ie channel 4 goes to channel 4).
Does anyone have a netgear router that they use the USB port to record to so multiple Z8’s can share that drive? I tried to map the readyshare path to the z8, but it won’t recognize it. Looking for the proper syntax or whatever so the z8 can map to it.
Any idea why the full EPG is showing different programs than the single EPG? It’s only for certain channels and they seem to be off by 6 hour or so (meaning if I scroll forward or back, it then lines up for that single channel but the others are then wrong). I’ve tried UTC and normal mode, adjusting the EPG offset. Fixing one messes up the others. Provider insists they’re not wrong, and using other apps on the firestick support them. I’m at a loss.
