MOL2 --> Settings --> Auto-framerate OFF
Posts by Strock
Hi, it seems to be fixed with the new beta
it's written that you may have to do a factory reset if your issues still appear after installing the release
I recently started to watch TV series with MOL2 but I have an issue, it often crash with a grey screen and this message "Failed to load VOD data --1" or "Failed to load VOD data". It seems to appear more often with high quality streams so I don't know but maybe RAM issue ?
I'm connected in XC.
Live TV works fine.
I don't know if someone already had this problem but some help is welcome
Thanks in advance
Settings --> Storage and reset --> My USB --> Erase and format as removable storage
Edit : i realized my mistake by doing it again, i didn't see that there are 2 format options..... internal storage and removable storage, sry for that
Hi, same for me, it keeps saying "storage not connected" even though I re-formatted and chose the right external USB in timeshift settings
(record works)
Thanks for the help
I tried the second technique and it works, the IR extension blocks it, curious bug.
Thanks guys
So, sorry Lucky but I didn't try yours
I'm not at home, tomorrow
Thanks I'll try
Can you post a photo of your actual remote? Not a stock photo.
It's exactly the same, I don't have it now, I'll post it later
Quick question: Why not just have it on standby?
Because I want to have my IPTV portal in MOL2 load at startup everytime and not to use the refresh function.
Only the white button above on the remoto where you can set the box on or off
I tried to press this button but it only works in stand-by mode...
It seems that this issue was mentioned with the Z7+
I recently bought a Formuler Z Alpha and I have a problem :
By default, when you press on the power button the formuler goes in stand-by mode. I changed this setting to "power off". However, now i can't power on the box with the remote control, I have to disconnect and reconnect the power supply.
Is there maybe a "special" button on the remote control to power on the box while it's in "power off mode" ?
Did someone already encounter this issue please ?
Thanks in advance
