The Z10 remote has some functions missing so we wanted to use our Z8 remote. The light on the Z10 flashes but nothing happens, is there anything we can do in the settings to make the Z8 remote work on Z10?
Posts by corewindow
Is anyone facing anything similar?
Sometimes, I pause the live TV then press play and it continues from where it left off. However if I pause it again and then press play again, then it restarts from when I paused it the FIRST time which means it goes all the way back. How do I stop it from doing this?
Hi
It seems that quite a few of the IPTV providers require a VPN to work in the UK. I was wondering if anyone could recommend a VPN which pretty much stays on permanently? I've found that with some VPN's, we keep having to activate the VPN software again and choose a server, we have to do this numerous times.
Have you used the menu button on the remote and selected “TV series” ?
Yes
You need to use portal login
Yes I am signing in through the Portal URL.
Is there anybody that has experienced this issue before?
None of TV series show up on the MOL2 app but it shows on the other apps, do I need to change anything in the settings? The VOD section is fine.
I have signed up for the free trial but I am struggling to figure out how to do it. Is there anyone who is familiar with Xtream Editor?
I use xtream editor, you can merge 2 lines into one link.
That's great! Would you be able to teach me how to do that? I tried to PM you but I don't think it is letting me PM you.
I have been researching it and apparently it is possible with Xtream Editor, does anyone on here have experience with this?
Is it possible to combine 2 different IPTV subs into 1? I want to purchase subs from 2 different suppliers and use both of them at the same time instead of logging out of 1 Portal then logging into the other one.
Thank you! I will follow those guidelines.
Hi
I have tried to research on adjusting the buffer time in the settings however I still can’t figure out what it does and which would be the optimum setting. Can anybody advise me on this please?
Thanks I will check, apologies about the questions. I just have a final question, could you guys advise which is the best VPN to run on this box with MyTvOnline2? As I know that some people have issues with certain VPN’s on our box.
Thank you for your support Mevi, I was trying to download it from the Google play store originally!
I am thinking of getting another box for a different room, instead of using a long Ethernet cable ( and trying to hide that) I’ve been advised that a TP link will be just as strong and reliable as a hardwired connection for this, what are your opinions?
Sorry yes internet speed test
Thank you for replying, that’s great. Do you know how I could do a speed test on this box?
Hi
I am new to IPTV and have just purchased my Z8 box.
I was advised to download the 'Clean Master' app in order to clear the cache and keep the box running at its optimum performance. However, I just found out that we can just clear cache from the settings on the box, does this do the same thing?
