None of TV series show up on the MOL2 app but it shows on the other apps, do I need to change anything in the settings? The VOD section is fine.
TV Series
Is there anybody that has experienced this issue before?
all works here with 3 different portals nothing in m3u i haven't put url in I'll have to look later
You need to use portal login
Yes I am signing in through the Portal URL.
Have you used the menu button on the remote and selected “TV series” ?
Yes
I have the same issue with series bit not movies
