Posts by SayUncle
    I do like MOL3, but, IMHO, it seems like a bit of a step back to remove the "All" selection from us. I really hope this choice gets added back in an update.
    BTW, is there a place we can give our feedback on MOL3 to Formuler to perhaps push them a bit to bringing All back?
    Glad I found this, as I have been trying to figure "what am I doing wrong" out. Well this kind of sucks. on my new Z11 i get only one choice for a particular news station, while on my Z7 with "All" I get different three selections of the same channel, 2 in HD and 1 in SD (with the same provider on both units). At times it has been helpful to be able to go to another channel selection if there ever is sound issue. Is this a done deal or is there a possibility that the "All" selection may be added with MOL3 in the future on a Z11?
    Hi adrilang , thanks for the suggestion. I did try Total Commander as well, but not File Commander. Do you have the version number that seems to work for you and I'll download an APK for the exact same version, so it will be apples to apples. Thanks.
    z11pronotmax , I see, thanks for the reply. I knew it was something that I couldn't get to the bottom of to correct, as I usually persist, and with the help of the forums figure things out eventually.
    I wonder if this is something that can be over come with a correctly coded File Explorer, or is this something that just has to be lived with going forward with Android >10.
    Is there a way to access system files on my new Z11 Pro Max? Last week I upgraded from a Z7 and there never was a issue having full access to Android > Data using an older version of ES File Explorer. On the Z11 it shows the Data directory as empty. I've tried a number of file explorer/managers, such as, a newer ES File Explorer, Solid Explorer, MiXplorer, CX File Explorer, and a few others, all with the same result....directory empty (yes, I know to check Show Hidden Files). I have gone over all my permissions a few times now and I think they are good. Any suggestions? Thanks.
    So I purchased a new Sony Bravia 75" and it works very nicely. The problem I am having is, for reasons I can't determine, on the Sony input choice menu my Z7+ drops off the list after a while. For example if I am watching Kodi or Mytvonline, which is on HDMI 2, and I press input on my remote and I switch to HDMI 1 to watch my TV set box, if say 20 minutes later I hit input to go back to my Z7+, it is no longer listed on my input choices. I then have to unplug the Z7+ to reboot and then it will show back up on my input choices, it is listed as Z7_Plus when it is on the list. It has never dropped any other input choice.
    I have 4 HDMI inputs on my TV, #1 is for regular cable TV, #2 Z7+, #3 Sony sound bar, #4 open. I have moved it to HDMI #4 where the same thing happens. On my old TV, an older model 65" Sony Bravia, it never dropped off the input list once.
    Any thoughts or advice would be appreciated.
